Can someone recommend a part please?
ts2340
This keeps popping out. Can someone link what I would need so this doesn’t happen anymore?
Thanks
You have a few options actually so just giving one part number would not really help much
First you could purchase a new shock and put a little bigger screw or you could just get a set of suspension links and screw those on to your old shocks and use different screws putting it on.
Second you could get new A arms for the rear that are metal (use loctite) or you could simply,
Put a screw with a nut on it just dont over tighten because you could just snap the link off the shock
This is probably the quickest and easiest. Do you know the size of the screw? I'll have to get a longer one and want to make sure it's the right thread size. Thanks mate!
I believe that is a m3 shoulder screw that is already in there you will want to stay with the m3 screw but add a nut to it WIN_20200222_01_37_08_Pro.jpg
Sorry this is the best pic can do at this time of print this is a fine thread m3 screw with simple non lock nut to attach the front shock assembly on mine. I do not run with washers and I just go to right past hand tight for me and tighten as I test. I would not go too the point where you need to ( wrench on it) at that point you will need to source out one of the other options.
