1/18 ruckus servo help please
thatryan
This truck is a few weeks old and barely turning, sometimes gets stuck turning until re turned. I want to try resetting the servo but not sure how to take it out? Or even get horn off, any tips?
Thanks.
Lephturn
Ok so take the servo arm off and examine the teeth. Is the arm slipping on the splines or is the servo itself stripped?
thatryan
Nope, all the teeth look fine... if I power it up and turn wheels with transmitter with my finger on servo case it’s very noisy and can feel a lot of movement inside, not very smooth feeling. Not sure if that is normal..
thatryan
Thought that may be the case. Bummer.
any special way to install a new one? Centering or anything?
Thank you much
Lephturn
Be sure to hook up the receiver and servo, set trim to zero the turn the dual rate down to zero. Put the servo arm on after it has been zeroed to get it close to center.
