Jeremy in WI
So check this out, I was toolin around the living room with the little barrage when it suddenly slowed to a stop while 2 or 3 minutes into a fresh battery. Then instead of driving (fwd or rev) when I work the trigger, the front wheels turn to the left. Forward command turns (left) gently, reverse turns (left again) dramatically and holds. Steering command does almost nothing. I tried to rebind and I topped off the battery with no change. I contacted horizon and they sent me a new esc/rx. I put it in and I have the exact same issues. Could this be the TX? Or did I get lucky enough to start out with a bad esc and get an equally shot replacement?
