4wd ruckus front drive shafts
hogface
Where can I get after market front drive shafts or know anyone that has them?
I bought the Hot Racing Steel CVD Drive Shafts ECF288VX06 for my 1/10th 4WD Ruckus. They fit front or rear and were $48.88 on eBay. I was tired of breaking drive shafts, so I went with something really beefy. I just installed them but can't test yet because a 6mm hole is required for the wheel hexes, so I'm searching for some. Stock wheel hexes have a 5 mm hole. I might drill out my wheel hexes if I can't find some quickly and reasonably priced. These shafts require the disassembly of the transmission because the stock differential outdrive is replaced by the outdrive that's integrated into these drive shafts.
I drilled out the 5mm holed wheel hexes, but the new hole was a little off center, so I think that was a bad idea. I found these Tekno (TKR1654X ) 12mm hexes with a 6mm hole for $17.99 at www.amainhobbies.com. Hot Racing has them too at the same price.
