Turtle24
- Location
- Ontario, Canada
Is there any aluminum parts out for the ruckus? Id like to get shock towers, casters and suspensions arms for my ruckus.
Be careful where you put the aluminum parts on your rig. Just blinging it out with a lot of aluminum parts makes for a very heavy and actually very fragile truck. Personally I'd never do aluminum A arms. Castor blocks or steering hub sure thing, but the arm takes so much abuse the flexible nature of plastic just is better suited.
I dont trust the metal shafts on a basher. They will bend. The drive shafts take a real besting if you're doing the damage to the truck that I do. Lol I'd probably Bend them the first jump
I ordered the hot racing 87 tooth steel spur and it destroyed my pinion. Lol. (Need hardened steel pinion) I destroyed the plastic gears in my trans because I had the break turned up to high and a few lock ups on pavement took care of that.
How many packs do you have on the second hot racing driveshafts so far? I've looked at them a few times. I need metal steering, metal caster blocks and bearinf carriers.
