"AMP DB" off-road speed runner
95PGTTech
Premium Member
rural NJ
June 2017 - Ruckus purchased RTR for my dog to chase after I broke my leg, gets boxed in attic
Dec 2021 - son sees it cleaning attic, shows interest, use it as a general basher, slowly modifying
Mar 2022 - introduced to off-road speed running group online
Oct 2022 - Ruckus went 50mph on grass, setting the new record for 2WD (any scale)
Jan 2023 - After going 51mph, a 2WD slash goes 52
Oct 2023 - Retake the record, 54mph. Later go 55 then 57
Mar 2024 - the same Slash goes 58mph
Jan 2024 - After 4 different ESCs (since 50), 8 or 9 motors, 4 battery setups, 3 chassis, 4 transmissions, and countless suspension, ballast, aero, and wheel changes we have decided 57 is the limit for this chassis. It's high center of gravity limits its high speed stability and aero. Don't worry, it's still in one piece and gets driven often, retired doesn't mean dead. I really wanted to build a maximum effort, ground up chassis with the ECX name to try and re-claim the 2WD record and be the first to break into the 60s (the fastest 1/10 scale outright is a 4WD at 68.7mph).
This thread got the wheels turning. I have been referring to it as an "AMP DB" because it does use ECX1017 chassis and ECX1029 top plate, but the list of other ECX brand parts is really short after that (similar to the Ruckus or any race vehicle). It never was a boxed RTR at any point, it's no longer stock wheelbase or track width and has entirely foreign front end components (Team Associated), and it never ran the chassis in stock form. I will be attempting to use a stock but modified ECX body.
The following is the list of parts someone would need not included in a RTR car to replicate this one:
(I will modify this as parts change)
chassis:
XTREME Racing G-10 frame extension kit
XTREME Racing Ruckus G-10 battery strap
25T aluminum servo horn
H-R aluminum bellcrank ECT4806
TRA6846 steering linkage (modified)
Team Associated 71094 DR10M front bumper, uprights
AJCMods DR10M aero bumper/front splitter
AJCMods DR10M GNSS mount
FastEddy bearings throughout
front suspension:
GTR-XXL 7462 shocks 40wt
VG Racing springs "1/10 race tuned"
Amazon 65mm turnbuckle camber arms
Amazon 70mm turnbuckle steering tie rods
Amazon aluminum front shock tower
JConcepts DR10 bulkhead 2875
JConcepts DR10 pin brace 2876
Team Associated 71127 front axles
Racers Edge aluminum caster blocks RCE1925
Team Associated 91402 caster block bushings
aluminum steering blocks C29608BLACK
Team Associated 91394 inner and outer hinge pins
Team Associated 71068 front control arms
rear suspension:
RPM control arms 70462
RPM axle carriers 73572
Amazon 85mm turnbuckle camber arms
electronics:
Yowoo 4S 100C 6000mah battery
Hobbywing Max10 SCT
10awg 4mm ESC extensions
Hobbywing EZRUN 3600 3200kv
Dumbo X6 with gyro X6FG receiver
20kg Amazon special metal servo
SKYRC GNSS (GPS speed verification)
drivetrain:
Traxxas 6852A HD axles
H-R 81 tooth 48P steel spur
31 tooth 48p steel pinion
ECX metal gear set 9001
red wheel bearing grease packed
differential JB welded
Proline Badlands on Proline Raid wheels MX28HP belted 10174 (2.10 x 5.02) front
Proline Badlands on Proline Raid wheels MX28 10125 (2.70 x 5.05) rear - fishing line belted
Proline 6x30 to 12mm aluminum wide wheel centers 6637-00 front
Proline 6x30 to 12mm aluminum wide wheel centers 6637-01 rear
Amazon 12mm aluminum hexes
Yokomo ZZC-N4FLTA
IMG_0957.webpIMG_1023.webpIMG_1013 (1).webpIMG_4611.webpIMG_4613.webpIMG_4628.webpIMG_4630.webpIMG_4626.webpIMG_4674.webp
Currently just waiting on the rain season to end. We have learned the hard way about being patient and not running racecars in less than ideal conditions. You learn basically nothing of value about the setup and risk wadding it all up into a scrap heap (which has happened, see the Ruckus thread). I got a chance to take it around the yard a few times and make sure nothing is catastrophically wrong. The tail was super eager to step out so I switched from the narrow MX28HPs square to the wider rears and pulled the ear plugs out of the rear diff and fully JB welded it, which improved it some. It's probably going to need some spring and shock changes to help it squat better and transfer that power to the rear. It's clearly way too powerful for our acreage which is generally around 30mph. I'm going to try and keep a wheelie bar off this if I don't have to.
Looks pretty cool with the DR10M front bumper mount, AJC mods aero splitter, AJC mods DNSS box. Had to clearance the splitter for the wheels and tires. Promptly snapped it off first test run and ordered another. Actually cartwheeled the whole unit and was lucky to get off with just the splitter breaking. I need a brace from it to the front shock tower.
Did other little mods like put a brace between the front shock tops because I wasn't a fan of how much force they were going to see with the standoffs. Ordered GTR-XL shocks for the front (shorter than these XXL) and all five spring rates Traxxas offers for the XL and XXL to play with, going to start with much softer in the rear. Still an absolute swamp out there.
