Barrage axle upgrade?
Johnson
Hello, I have barrage, and wanting to upgrade my tiny axle (front/rear). I want to know Which axle would fit my barrage? Any help would be great.
Here's my notes on lengths. The link lengths and placements will have to be figured out by you.
-Yota II/Gelande II - 1/18 -92.2mm
-Yota 180 mm, 7.08 inches
-Scx10 192 mm, 7.56 inches
-Sawback 183 mm, 7.205 inches
-MST cfx 194 mm, 7.638 inches
-Ascender 192mm and can be narrowed to 180mm
-AR60 245mm/9.65"
-Losi MiniRC/SlickRock 140mm/5.51"
Unless you are trying to widen it there is no reason to replace them. You can rebuild them quite stout and they look much more like a scale axle than say an SCX10 axle. Put aluminum lockers in there and aluminum chubs/knuckles and lockouts and they hold up really well. But if width is the issue then you're stuck spending about $100 to get a couple of axles.
