So yesterday I was running my boost with a 2S LiPo and 5700 kV motor. I hard a loud noise that started getting worse and then the car wouldn’t move anymore. I went inside and took off the gear cover (I was thinking I stripped my spur gear again) and I found that the spur and pinion gear were fine. So I then took apart the transmission case and I found that the idle gear was almost completely stripped out. There was no grease in there (and if there was there wasn’t much left) and all the plastic was everywhere on the inside. So I ordered a new ECX Metal Gear Set. When it gets here, do I need to clean and grease my transmission case or is it supposed to be dry? I don’t have any money left after spending almost $30 on the new gear set so I can’t buy grease. I might be able to find something in my garage but I’m not sure. Is there any substitutes I can use that will get the job done? Also, does the new diff come greased? Any response would be great because I’ve never touched the inside of my transmission case before.
Thanks,
Ryan
Thanks,
Ryan
