ESC fried??
Nukem
I got a 1/24 barrage...super fun rig. But now when I pull the throttle I get no wheel spin....just turns to the left. I get perfect response from turning servo...just no forward. I got full reverse.
kruzracing169
ND, USA
Sad to say, stock electronics are on the cheaper side of things.
Leaning towards bad ESC.
Steering is Servo.
Fwd/Rev is ESC.
Think about it being simple terms.
You have steering, servo good.
No movement in motor, either ESC or Motor.
You can always use the reverse switch on radio to see if motor spins other way. If so, ESC is done.
Upgrade time.
K-SpecRacing
All connections are good. And it doesn't play that little tune when I turn it on
I'm leaning towards the motor since mine had this happen and it was the motor (though I had no reverse either). Either way though, upgrade both 😋
