Fit?
RJL
They should fit but I believe the Losi has a slightly shorter wheelbase than the temper so that might come into play. Honestly I wouldn't waste your money on those, just do a 4 link setup. You can get parts 3D printed right from shapeways from Dravtech. Links are easy to make. https://www.shapeways.com/shops/dravtech?section=Losi+Mini+Rock+Crawler&s=0
Rear 4 link mount https://www.shapeways.com/product/CGSDXZ3RT/losi-mrc-rear-upper-link-mount?optionId=41728784
Servo plate/front 4 link https://www.shapeways.com/product/C...link-mount-for-the-losi-mrc?optionId=20967513
If you are strictly rock crawling then yes 4 link is the way to go. Way more stable/predictable movement of the axle. Plus its helps a ton with the dreaded "torque twist". If its more of a basher/trail truck or something, then its not as necessary.
