Good sites for Torment hop-ups
Hot racing has some parts (shocks?), T-bone racing (TBR) makes nice bumpers (not sure if they have one for the Torment though), RPM has replacement plastic parts which should be more durable. And Fast Eddy has bearing sets if you get water or dirt into yours. Horizon also has its own line of hop-ups which are actually quite good from what I read (but a bit overpriced IMO).
I think RC Screwz has a stainless steel screw set for the Torment as well.
I have spotted 4 seriously bent screws on my chassis so I'd say yes. All the longer ones in my Amp are too soft for the use they get.
I know this is an older post, but this is a really good match up for a upgraded parts list.
Also, check out RC Overload on YouTube, he bashes a 2wd Torment with upgrades.
T-Bone racing bumpers
#Sect288rc Light weight steel CV Drive shaft, Hot Racing
#ECX9001 Tranny Metal gear set, ECX
#85-45-BND 80A ESC and 550 Brushless motor, Hobbystar
2s or 3s - 4000 MaH LIPO battery 25c, Dynamite
#70672 Sealed gear cover, RPM
#70462 Rear A-Arms, RPM
#70582 Front A-Arms, RPM
#ECT1906 Aluminum caster block (front), Hot Racing
*run 5x11 bearings*
#73292 Oversized front spindle blocks, RPM
#ECT2206 Aluminum rear hubs, Hot Racing
*run 5x11 bearings
#ECT1006 Aluminum hex wheels, Hot Racing
#3643 Rear tow link(turnbuckle/camber link) ,Traxxas
#3644 Front tow link (turnbuckle/camber link), Traxxas
#3643 Front steering link(turnbuckle/camber link), Traxxas
Pro-line Flotek clear body
#6063-00 Power stroke shocks(front),Pro-line
#6063-01 Power stroke shocks(rear), Pro-line
#6308-21 Pro-Spec spring assortment (front), Pro-line
#6308-22 Pro-Spec spring assortment (rear), Pro-line1
Tires I like to run, my preference for just tearing I up.
#182-01 (4) Badland's SC 2.2/3.0 M2 Fr/R tires, Pro-line
#1190-01 (4) Trencher X SC 2.2/3.0 M2 Fr/R tires, Pro-line
#1183-02 (4) Blockade SC 2.2/3.0 M3 Fr/R tires, Pro-line
#1501-MG Power Hd 1501MG 60G metal gear 25T servo, No namer (eBay)
#ECX331007 Servo arm, aluminum, 25T spline, ECX
#73492 (Servo-saver) Sterring rack, RPM
I hope this list helps.
List was made for the 1/10.
I don't know what is offered for the 1/18.
Check out You Tube. Just search ECX Torment 1/18 upgrades. I found a bunch, didn't watch them though.
Good luck
