Joshnewb
Looking for some 1/10 2wd buggy Front tires to mount on 2.2 wheels that are roughly 25mm (22mm from inner lip to inner lip)
My main question is regarding mounting tires that would be wider than the wheel itself.
The tires I'm looking at are 30mm (I know that's the widest part, not the part that's glued), and I was planning on using closed cell inserts. Will the inserts and tires work? Or am I stuck with narrower tires (ribs)?
tires: pro-line front 2wd buggy hole shots
thanks for helping a rookie
