How to clean your ECX RC's
WoodiE
Kind of good admin
Staff member
Lexington, KY
There have been several threads about how to clean your RC. I figured I'd share how I clean my RC's and others can share their methods as well below.
How to clean your RC
I first use a 50/50 mixture of water and Simple Green in a spray bottle.
Spray the RC down and let sit for a couple of minutes then wipe down with a clean rag or air blast dry with an air compressor.
For stubborn sports I will spray the RC again and use an old detailing brush or toothbrush on any hard to reach areas.
Optionally, you can use some WD40 on the RC after it's been cleaned to give it more of a shine if you like that kind of thing.
How to clean RC bearings
To clean RC bearings I remove the bearings from the RC and place inside an RPM Bearing Blaster then spray brake cleaner into the bearings to clean them followed by a light application of very light oil, such as this 3 in 1 oil.
If you have some terribly crusty stuff or really want to do a deep clean on your parts and/or bearings then check out a Ultrasonic cleaner like this one which you'll be able to easily fit all of your bearings as well as many other RC parts. I have one that I use from time to time and it does a great job making parts look near new after they have been ran through the ultrasonic cleaner.
Again, remember if cleaning bearings with an ultrasonic cleaner to also oil them!
That is how I clean my RC's. Simple Green, water, and a couple rags and toothbrush. How do you guys clean your RC's?
Have a Torment 2WD Brushless ECX03015, which says waterproof. When cleaning I remove only the battery and use regular showerhead when it is cold outside and a regular garden hose when it is warm enough with a flat brush. Off course I'm avoiding pouring tons of water directly on the electronics, but I am also not affraid to splash on it. So far all seems to be working fine.
Spray a light coat of wd-40 on afterward for rust prevention. You’ll be amazed at how new the plastic will look. Wd-40 water displacement on the 40th try.
The thing I know pretty shure isn't water proof is the receiver. That's why I designed my own receiver box and 3d printed it.
I have used simple green ,a brush and air hose. What are you guys using to keep you plastics and tires looking so nice?
I have ben thinking about trying Cow RC stuff?
A lot of people used to use, and still use WD-40 (the original) to livin up their plastics. I was never a fan of it. I've used the following products.
The cheapest one, and works great, is WD-40 Specialist Silicone Spray. If you care about stink, and don't care about price....SC1. I would assume most any silicone spray you find at your local stores would work.
