Is a motor with 5mm shaft any better than the 3.75 mm shaft I know the gears cost more
Alldave2003
Looking to buy a motor and have found different shaft options , is the motor any better when you get larger shafts or is it just a way to make u spend more on gears
Smaller shafts may be more prone to shearing off or bending. Larger ones should be more durable.
There are more options with a 3.5, and hobby shops have a better stock.
I know your just asking the question, but keep it simple.
You are running 1/10th scale, not 1/8th or 1/5th. I would stay away the 5mm.
If your concerned of money...shop eBay. You can get a whole brushless combo for 35.00 shipped to your door .
Dude, if your shearing off or bending, you got problems. Check your mesh, or don't use metal Spurs, stick to plastic, you need a breaking point.
Hahahaha.
Hahahaha.
I’ve never bent or broken one not even used metal spurs nothing but stock I have nothing against the 1/8” shaft
