Losi mini crawler driveshaft compatibility?
Dicke1976
does anyone if these will work on my temper!!??
The Losi Mini Rock Crawler has 4mm output pinion shafts and the Temper has 5mm output pinion shafts so it will not be a direct fit without some modifications. I have read that other people have successfully used Traxxas and other similar 5mm sized shafts on the ECX Temper but I have not tried it myself.
Thanks man I appreciate it
