Dowhat
I’m new to RC cars. Quickly burned up the stock motor. How do I space the gears when replacing the motor? I’ve read about using the paper trick on the gears. Do i have to pull out the entire transmission and motor assembly? Looking at the exploded diagram I don’t even see how that’s possible. The plate that holds the motor in place is off set and rotating that seems to move the gears in and out of sync. I’ve got it pretty tightly meshed where if I feed a strip of paper in it chews it up pretty good. Running the motor at slow to high speeds while holding it in the air doesn’t produce any grinding or other unusual noise. Is there any way I can tell if I’m good to go?
Thank you.
Thank you.
