Savvy_Savage7
- Location
- Pennsylvania
Thank youI replaced the hinge pins with longer 6-32 screws and ran them so they just came out in the battery box area. I drilled the a arms out slightly becasue the screws are a little thicker. I planned on installing a nut on the other end, but it wasn't needed. Its held up great for a year now, on brushless power with 2.8s. Did end up snapping one screw, so if you do this, grab a couple extra.
Now to be fair, i got this idea from someone else on here, i initially just used tent stakes i cut longer then the hinge pins and had them extended flush into the battery tray, with another set screw on that end holding it like the backside has stock. One of my trucks is still like that, but they aren't as strong as the 6-32s, so once they fail I'll use the screws on that one aswell.
