Roost Slipper Assembly
ESA1178
Hi all.
Trying to replace the slipper assembly on my son's Roost.
Haven;t been able to find any instructions online.
Can anyone help?
Ive been able to remove the motor and strut covering the shaft.
The car had been sluggish and it turns out the teeth are a mess..
Got a new slipper assembly and managed to remove the shaft but not sure how
to actually remove the slipper assembly itself.
Sorry, RC's not my thing and just trying to help out....
Thanks!
ESA1178
Thank you for replying Stephen.
I also have the parts schematics from Horizon Hobby. But it doesn't tell me how to remove the slip assembly. Horizon Hobby told me that they do not have instructions.
Happy holidays!
Mark
Stephen1806
After u get the drive shaft off go back to the trans and take the screw out the gear and pull it off
Stephen1806
Remove the cover from the gear
Reomve all on the bottom of the roost remove the 6 rear screws
Remove motor
Remove driveshaft cover
Remove hinge pin
Remove rear wheels
Remove the four screws holding the transcase together
Take off rear trans case and remove trans assembly
Remove driveshaft holder using 1.5 hex key
Remove the gear attached to the shaft using a x screwdriver
Remove the nut and washers
Remove bearing
Remove plastic retainer then pin
And pull off the gear
