Torment pinion sizes and pitch?
WithinU
Land of Oz
If my searching is correct, the stock pinion gear, for a Torment is 19T 42P with a .125" (3.175mm) Bore?
Is it just me or is it somewhat hard to find a 19T 42P 5mm bore pinion gear? Or a pinion gear set. that isn't $15 for A pinion gear.
The brushless motor I am interested in has a 5mm shaft.
WithinU
Land of Oz
Cool, thanks @X. I could find almost anything, 21T and over in the 42P 5MM bore, but had a heck of a time finding them for 19T.
So is the stock Pitch size 42 or 48?
X
Conspiracy of One
Staff member
Supporting Member
Should be 48p. Unless you have the brushless, which I think is Mod 1.
Which model torment do you have?
WithinU
Land of Oz
Brushed, I am pretty sure the manual said 42? Or am I wrong?
X
Conspiracy of One
Staff member
Supporting Member
Looks like 2wd uses 48p, 4wd uses mod 1.
WithinU
Land of Oz
Thank you @X, I must of been confusing myself, which is easy to do at my age. But we are good to go now.
I did refer back to the manual, and the pinion gear is a ESC1073, which is a 48P gear.
X
Conspiracy of One
Staff member
Supporting Member
Haha, we all have our moments. Good luck with the new pinions!
