Upgrade tire's
Rc resuce
Can this thing handle traxxas stampede tires or traxxas rustler stock tires. Can you upgrade the spur or not. All advice is welcome
kruzracing169
ND, USA
Scroll through some of the conversations. We could sit here and explain, but I feel the other subjects cover enough.
Traxxas wheels are pretty close to ECX if that helps.
Yes, you can change the spur. Team Associated with minor adjustments.
Otherwise, stock with different pinions.
i_r_beej
I'll second that. The Boost is 90% the same as the 2WD Circuit and AMP MT/DB. In fact the only real difference is that the Boost has a slightly shorter chassis and shorter swingarms (so, a shorter wheelbase and narrower track). Any gearing changes/mods that can be made to the Circuit or AMP can be made to the Boost.
Here's a thread in which I detail the modifications I made to my AMP to race it. I cover changing wheels (a disaster) and the spur gear. https://www.ecxforum.com/threads/converting-the-amp-mt-to-a-circuit-st-to-race.878/
