What size connector Max10 SCT 120A
REDdawn6
Max10 SCT esc 120 a
I am trying get this installed and work.
I have 4mm connector on the motor but the 4mm is too small for the esc side of the esc. What size connector / adapter do I need?
The one's that came with the esc are not the right size? If plugs in the motor fine but too small for the esc side.
95PGTTech
Do you mean the bullets on the battery connector? It's an XT90, which you probably don't have on the old setup, and looks exactly like a XT60, just larger. It should indicate that on both connectors. Do not run an adapter.
What motor are you running? We can look up the bullet size
WithinU
Land of Oz
I'm pretty sure the max10 SCT ESC's female bullet size is 4mm.
Now I will say, that the GoolRC motor and the other motor (brand name eludes me right now, it's blue Onyx?) do in fact have smaller bullet sizes, or at least mine did.
Also the only thing I did was swap out the XT60 for a Deans, I know I know, I was already set up with Deans.
95PGTTech
I had a moment so I just went and mic'd it, the male bullet measured 3.99mm. The ESC connector is an XT90 on both of mine.
You're probably fine with a deans on 2S, maybe even 3S. But that's doing the ESC dirty, gotta put 4S to that thing it can handle it all day every day.
REDdawn6
It's a, probably, 3-4 years old hobbywing 3200kv motor
