Witch one to get
Ok so I've asked already but about to bite the bullet and buy steel TRAXXAS axles for my 2wd torment. I've been told the 4wd SLASH axles work on the 2wd TORMENT an I've been told the 2wd SLASH axles work for the 2wd torment. So before I spend the $ witch way is it an has anyone tried STEEL TRAXXAS ones an if so witch ones
I used the 2wd slash axles but again you have to shorten your output shafts On your torment. If you have a powerful motor you will break these as well.
You could also drill out the yoke of the driveshaft deeper so the output shaft goes in all the way and wont have to cut down the output shaft.
I just used a good file and cut how much maybe a mm or half but yes drilling the axles is a great idea too.
So i would need to drill this part like this? So the driveshaft can fit in farther
Wait it turns out it hits here too it hits the top part
