jimboEcx500
Does the UK ever have dry weather?![]()
but crap recently
Note: this_feature_currently_requires_accessing_site_using_safari
its straight hopefully be fine. what thickness gasket paper do u use? transmission case coming soon
just need some dry weather in uk to test it out }}
cheers for u help![]()
ok that sounds good}} ill order roll this on ebay. ive got the glueThis is what I use, just what the local parts store had. I was having all sorts of clutch slip issues with big power another member on here called me and recommended cutting my own, light glue to the spur so they can’t spin, then rough it up just a little with coarse sandpaper. Rough the plates up too. Took the spring completely out, I put on m4 nut on and set my clutch (full tight then backed off 1/6 turn - one flat of the nuts). Then loctite on the remaining threads and run another m4 nut down and tighten them together. Prevents the clutch from coming out of adjustment or big power compressing the spring under load
Glad I could help, try to post a follow up when you solve the issue so if someone in the future has the same problem they can see the solution
I tested today and squealing sound ? it's not rightYeah that looks right, two planetaries (sun the big one) two spiders on a dog bone. Since there is no option for a locker anymore for these you can put some real thick fluid in there or pack it with putty/epoxy
I've tried everything with this car
Very frustrating
maybe its the motor could be bearing gone ? }} ive only just noticed the brushless motor is inrunner for rc boat
could this be the reason ?
Very frustrating
ill give this a go. ive ordered losi 84t spur gear and slipper pads toOk let’s go back to isolating where it’s coming from. Take off axles, will tell us it’s motor/trans. Then take off pinion, will tell us motor or clutch/trans (or pinion/spur mesh)
see if that makes difference. read few reviews saying better setup than ecx
put losi spur in with new pads still hear slip and squealing sound. no matter what u try always hear squealing and no wheelie anymore. just spoke to local hobby shop and he saying losi slipper pads not designed for that amount of power. saying use sandpaper material. ill try the gasket roll u recommended on ecx metal spur see how it goes }}I had hot racing metal spurs from 87-81t. Any 48p spur with the same center diameter should work, the one in my picture is associated #9648 plastic 69 tooth. You could also swap to 32p if you swap the pinion too to something like this
https://a.co/d/0eygCsf
But 48p is really fine as long as you set the mesh correctly. I would only go through the effort of the swap if you need a gear ratio not available with your current setup
