Upgrades and ideas
Johnthebatman
Hi everyone, first time poster.
I’ve been searching for upgrades and replacement parts recently for my Temper Gen 2.
basically what I’ve discovered is there just aren’t many upgrades for it yet. Is this common or are there any hidden gem sites?
last night I broke a piece of my front axle off that basically holds the whole front end in place. Realizing I might have to just replace the whole front axle, I wanted to see if there are stronger ones that can handle a little more beating.
I've read that a 2s lipo will also fit the gen 2 which is something I plan to do today as well.
Thanks in advance everyone!
The axles are easy enough to find and replace. If you haven't opened them yet, it's good to grease the gears. As far as upgrades, I haven't found much. Although there are redcat gears that fit if yours doesn't have metal.
I replaced my rear axle after breaking it. I put expoy on the upper link mount to reinforce it. We'll see if it works.
What did you replace your rear axle with? I broke the upper link attachment point on mine after about a week. I temp fixed it but of course it broke again so I think it will need to be replaced or I'll have to continue to fix it.
If you’re looking to upgrade axle assemblies I had RedCat Racing gen 7 portal axles on my barrage, they’ll work on a gen 2 temper with the appropriate parts you would just have to change a few things. Also a $15 “servo on axle” mount will be needed. I now have them under a Dinky RC Gen 2 Temper chassis. Crawls great
https://www.amazon.com/Redcat-Racing-Portal-Designed-Crawler/dp/B07MFRS6RN
Hey guys i want to upgrade my temper. Can anyone either tell me which diffs from redcat will work, or which axles. I saw the gen 7 portals, but idk if i want portals. Thanks in advance, i really just eant metal gears for the the trans and axles, but if that cant happen I'll out new axlea under it that i can get metal geara for. Thanks again.
