In the picture below you can see what I mean.It's the same fix for both types of axles.
At the end points of the axles, there's a spring on the shaft. That spring lies in an indentation in the shaft, to make it more difficult for the spring to be able to "jump out" from the intended position. When you remove the spring, you will see lock pin from the joint of the axle (moving part). When you put a lot of torque through the axle (too strong motor for instance), the force of the rotation will force the pin to exit the shaft through the winding of the spring.
So, you take a piece of heat shrink that is a bit too small to fit over the axle.
Stretch it a bit with the use of some needle nose pliers.
Stretch it just as much as needed to use a bit of force to slide it over the spring area.
Make sure that the piece of heatshrink is wide enough to fully cover the spring and about 3 mm left and right of the spring. That way, you will have a proper seal.
Because the piece of heat shrink is a bit too small, when you do heat it, it will shrink more than a piece that was bigger than the diameter of the shaft. This will ensure a real tight seal around the spring!
If you do it correctly, you will even see the contours of the spring through the heat shrink. That will ensure that the winding of the spring cannot be altered by the rotational force. To furthermore strengthen the fix, apply another piece of heat shrink over the already applied piece. This time 1 size bigger (diameter of the heat shrink) is recommended.
That's the fix I ave applied on ALL my steel drive shafts!
The drive shaft you posted, is actually the first type that I've modified...
They were on my Torment in the first place, but after the pin got ejected, I decided to buy the type that you see in the picture below.
However, having 3s on my Ruckus, and only 2s on the original ECX brushless Ruckus from my son (with a bigger pinion) gave me the same issue...
That's why I have come up with this fix, and so farit has performed very well
I hope this explanation clears things up a bit.
-Dave
