Just a stab in the dark, but in your partaking of the RC air ballet, you could have damaged your ESC/RX component as well.
Did you happen to test the old servo on the other car to see if it worked on that one too like the new servo?
IF the ESC/RX is the same in both cars, try swapping that out from car to car, and see if the malfunctioning servo follows. If it does follow, than I would highly question the ESC/RX component.
I may know the issue as I Literally just had the same exact problem almost to the T as you. (Ticking, no response, & all).
I myself am fairly new to the hobby, & just realized I did the newbie mistake of not calculating the total output of the new totally overkill of a servo I accidentally bought (25KG) for a replacement for a teensy, normal, MICRO SERVO!
I was impatient & frustrated at the time & learned a valuable lesson thinking it was my brand new huge, bigger than my rc servo that was the issue as I bought it fairly cheap online. I was disappointed it gave out after a few hours. I ordered the correct part afterwards & when I connected it to my receiver, it too was not working! Now I'm really frustrated thinking I may have bought an expensive replacement for a cheaper totally wrong part. I did as you did with troubleshooting, wire switching & everything was just fine with the receiver input but neither servo worked. I was beyond baffled, I even had to take a minute to recollect what was happening. I thought I was for sure screwed having to buy a whole new receiver & remote perhaps. Looking at prices online, & how much I had spent on it so far, I reconsidered trying one last time to figure this out.
Again, I did as you tried, (all this prior to me stumbling across this thread)***
I swapped out my ESC since I did have a sparebrand new one in case, & soon as I plugged it in, BAM! IT CAME ALIVE!
Right at that moment it slammed me like a ton of bricks, IT WAS WAY TOO POWER HUNGRY FOR MY STOCK ESC AS I LITERALLY JUST READ ABOUT A FEW DAYS AGO ONLINE! the servo required a MINIMUM of 6.5v all day to function properly. My poor 60a ESC was SUFFERING trying to keep up the power demand of that beast!
I went back online to look at its specs, wow....I basically tried to fit an elephant in a size 10 shoe & only managed to barely keep one toe inside! It was a High Voltage servo!
Glad I didn't kill my receiver first! Also during troubleshooting, I've learned a few new things! The possibility of using the turning knob of the control to use as fwd & rev function when switching wires (sounds no brainer but it's not supposed to recognize such functions!) && also using ch.(x) also as a function of movement when plugged in & switched over accordingly. Only thing is you only get 1 speed....MAX
So yea hope this helps bro.
sorry had to share my struggle incase someone comes across it also.
