Stamatis
Hi, everyone,
IMO, this is the list of "must do" things in order to transform this little crawler into an unstoppable machine.
Cheers,
Stamatis
- Lubricate the drive train. Out of the box there is no sign of grease anywhere! Tear it down and add some.
- Rotate battery plate, helps a lot in better weight distribution.
- Add some o-rings between the springs and the spring holder, that will make the suspension more stiff and minimize torque twist.
- Add a MG servo and a servo saver (can skip that step, stock servo is quite reliable).
- Extend by 5mm the upper axle links to eliminate driveshaft stuttering.
- Add some alloy wheels, most of them are heavier than stock ones and improve performance.
Cheers,
Stamatis
