1/10 2wd shock sizes?
wolfzr2
Are the rears 105mm, and the fronts 90mm?
Right out of the box, the fronts are leaking like sieves. I've dumped the factory oil and put in Associated 30wt, and teflon taped the bottom threads. We'll see how they do.
If I want to replace with aluminum shocks, I'd like to know the sizes to get.
Looking at the Hot Racing blue aluminum sets. Anyone had luck with those?
I measure 105 rear and 90 front, center to center of the mount holes.
Let us know how the HR shock work out, I bought the ones through Horrizon, though the body is metal the caps are still plastic like the stock ones.
I run 30wt front, 25wt rear of Team Losi silicon, no major leaks since install months ago.
