I've been running my Amp MT on the hpi branded flux 4000kv for the past year or two. The motor does get hotter than I like, though, and even when moving at pretty high speed it does a wheelie when I get on the accelerator. I actually have to be really careful not to do flips, I definitely will be putting some weight up front, too. Since it has too much speed and power I'm going to check my gears, I have a couple spur gears sitting around and one of them might help all of these issues.
Stock gears were fine, but I bought Team Associated metal replacements and decided to use them, well most of them, there is still at least 1 plastic in there somewhere because looking through parts the Associated bag still has the big plastic gear, so I must have left the stock in there on purpose. I may find that it's a better ratio than the one sent with the Team Associated kit.
The motor came with heatsink and fan but no three wire connector to fit my ESC(also hpi branded), I may try connecting the two wire fan to the three wire ESC if I can dig up the proper piece of electrical converter/connector. Even without the fan that heatsink would help, so I'm going to take the little fan off and just put the heatsink on if nothing else. I routinely take my laptops apart to clean and reapply thermal paste, I should be able to come up with a good way to attach the heatsink securely in place and then would be able to put some Arctic Silver on it ?
I destroyed the left front wheel caster block and the right rear suspension arm came loose twice on the day so I've ordered aluminum replacements for wheels, suspension, and steering. While I have it that far apart I might as well take the gearbox apart, too.
I'm using a Traxxis 25C 3S LiPo rated at 5000mAh, it's incredibly fun and crazy fast. I don't think I've ever had it at top speed but it has to be over 50mph. Trying to get to see what top speed looks like is what led to the recent destruction lol. I should have just had fun instead of testing my little Frankenstein's monster.
I thought I was saving money by buying the ECX Amp, but I've easily put $500 into it since buying. I probably get more out of it doing it myself, overall, but $650 would have bought a very nice short course truck.
