Best options from brushed to brushless
Rc resuce
I will be needing to replace my stock motor on my 4x4 ruckus. What is the motor for this machine? U guys have found that works the best
There is not one perfect motor combo. Get a brushless combo with a 3660 motor in the 3000kv area with an 80A or better ESC.
You can get a longer can (3670) for more torque, or a lower kv, or both. Also can get a higher amp ESC.
Let’s see what others recommend. My Ruckus is 2wd but has 1/8 Stadium Truck wheels and tires. I run a 3300kv and an 80A ESC and was snapping axels and tearing up the gearbox.
What batteries do you have at the moment? 2s, 3s or both? I'm with Taco on the 2400-3000kv on 3s. If you only have 2s batteries, the Castle SCT 3800 KV combo will get the truck scooting along nicely.
