valve90210
Hi
I'm going to be building an ECX Amp today and before running it I was planning on running the motor in using the water method. From what I've read ad seens, it's a case of submerging the motor in water and gently and gradually running in at different speeds for a good 10 minutes or so. I was then going to give it a good spray with motor cleaner to make sure any dirt etc from the process is cleaned out.
Is there anything else I need to do or consider before doing so?
