Can this ECS handle this battery?
Barilux
Hello ECX community,
I have a small doubt and wanted to be sure. I have a torment BL version, that came with this ESC:
http://www.dynamiterc.com/Products/Default.aspx?ProdID=DYN4940
Will I have problems connecting this battery with it?
http://www.nitrotek.co.uk/7-4v-5200...ery-with-deans-connector.html?fee=11&fep=9318
I know it is compatible, but is there a thing such as a too high discharge rate? From what I have been reading this battery can withdraw around 250A, is that correct? 5,2A X 50 is math im doing. Is that too much, or the ESC will controll the amount of current withdraw? Will I experiment higher heat from a higher discharge rate battery, or that is not related.
Btw: this is the motor : http://www.dynamiterc.com/Products/Default.aspx?ProdID=DYN4942C
Thanks
As long as your motor does not have the capability to draw more than the ESC can provide, you will be fine. It's not uncommon to use a battery that has a higher discharge rate than the system can use.
Higher discharge rating on the battery means nothing to the esc so long as your not creating a bottleneck effect. What I mean by this is if the esc wants a steady 100a rate and your battery is only capable of 50a discharge you my create a situation where one or the other will over heat due to the resistance created by the battery. Granted this is an extreme example... a good rule of thumb is to all ways buy a battery with the highest c rating you can afford.
