Note: This feature may not be available in some browsers.
Ok it has a 12t gear on it now and I would like more speed I’m running zippy 2s lipos on a goolrc ocday esc and motor.I am not sure you can get both, speed and torque, just by gear changing. You can get either speed or either torque.
Plus it would be helpful if you also told us what you are currently running. Gear wise.....batt, esc, motor, gears......ect
My temps are perfect I have a fan on my motor and esc as well.What are your current motor temps?
A 12 tooth pinion is pretty small. Get a 14, 16, and maybe an 18 tooh and start testing.
What type of motor are you running? (Either KV or number of turns).
If you stay with the stock spur gear (87 t) you'll do well with a motor in the 4000-5000KV range. 3000KV and lower and you'll want to install a smaller spur. I've found the Associated spurs are really easy to adapt-- drill out the center hold to 5mm and use the Associated slipper pads and you're ready. You'll need to install a pinion in the 26-28t range.
