AK4WD
I've just received the aftermarket aluminum body shocks for the ECX Torment (apparently fits other models) and upon installing them, I found that the spring retainer at the bottom of the shock hits the A-arm. I swapped out the spring retainers from the stock shocks, which have a bit of an upward taper and they seemed to help, I also found that the shock caps hit the front shock tower when installed in the same position as the stock units. There was no mention of needing spacers or any of that when I purchased the shocks. Has anyone else encountered this?
