ECX AMP Metal Axles
23lrupp
I've been upgrading my Amp, and I need to get some metal axles/driveshafts. What do you guys recommend? I've tried looking for the Hot Racing ones, but They are all sold out. Does Hot Racing make any for other trucks that would work on an amp? Thanks!
The hot racing axles are just about the best ones to get. Your best bet is to wait it out. The traxxas steel splined ones for the rear of the traxxas slash 4x4 work too but they are obnoxiously overpriced .
MIP are the best. A little heavy, requires a little modification to RPM hubs and you need to use locktight. But if you want driveshafts that will last longer then your car, MIP is hands down the best. The metal is high end tool steel. Dont use grease, it will act like a cutting compound. Dry lube if you need rust protection.
