Ecx barrage/temper gen 2 axles
you can buy a barrage doomsday and strip it you can also use the drivelines and upper lower legs transmission the same except for one of the shafts is a little longer but you can fit the larger motor from the barrage on the temper if you use some spacers to widen a chassis
