ECX temper linkage and shock adjustments
Pointy
so on my ecx temper, i did the basic lower link relocate and it worked out really well on the front of the temper, but on the back it just wobbled too much for it to be suitable for a scale look, so i dug in a little but further and found a simple solution for the rear.IMG_20190518_181553329.webp all you have to do is unscrew the top mounting points for the shocks and the upper link mounting points on the axle. put the upper links onto the inside of that box and put your shocks on the outside of the chassis and it almost completely stops axle sway left to right and it still had a decent amount of flex . ( dont mind my upside down shock i had the entire rear end apart for a good 45 minutes figuring out things) IMG_20190518_180922900.webpIMG_20190518_180944431.webp on another note, if you run your upper links flipped where the middle points up, the links will hit the chassis and will make the lowest point it can go a little over normal ride height
