If this is for the 1/10 2wd or 4wd I would go with the 3300 on 3s. 6800kv is way too high kv. In something the size of the Ruckus you probably don't want to go much higher than 4000kv.which do you think is better for a faster car? 6800kv on a 2s or 2800-3300 on a 3s? The 2800 maybe two teeth higher than stock on the 3300kv? Thoughts?
Where does Ecx list a 6800kv motor as an upgrade? Last I checked they only had a 3300kv and 4000kv motor listed in the option parts.1/10th scale 4wd. 6800kv is what ecxrc has for a recommended upgrade to otherwise stock brushless trucks, which is why I asked.
I don't know why they suggest that size motor...and I know, which is why I asked about a lower kv motor and a tooth change vs going to the 6800kv motor. It is strange that they suggest it, however I can only assume that they suggest it for some reason or another and it does make speed. Do you think they tested this or do you think that they just put it out there for the sake of putting it out there? Again, assumption is that they tested it. I could go the easy route and what has been documented, or I could go this route and hope that they did their r&d with this motor (little documentation on this motor or results using this motor).Now I found it. I am not sure why they even list the 5800 and 6800kv motors, but running those in a truck this size would just be stupid. Voltage and gearing makes speed not the kv of a motor. Why do you think most 1/8th scale trucks run 2000kv or lower motors?
I think its just a generic upgrade list for the 1/10 scale vehicles. That motor would probably be fine in the Boost and Circuit as they are much lighter vehicles.I don't know why they suggest that size motor...and I know, which is why I asked about a lower kv motor and a tooth change vs going to the 6800kv motor. It is strange that they suggest it, however I can only assume that they suggest it for some reason or another and it does make speed. Do you think they tested this or do you think that they just put it out there for the sake of putting it out there? Again, assumption is that they tested it. I could go the easy route and what has been documented, or I could go this route and hope that they did their r&d with this motor (little documentation on this motor or results using this motor).
yes, but they only make 4 stock brushless cars..which is what I would assume that they are gearing that parts list towards. Either way, skipping that specific motor.I think its just a generic upgrade list for the 1/10 scale vehicles. That motor would probably be fine in the Boost and Circuit as they are much lighter vehicles.
