Front hinge pin holder is in the ... Servo Saver set?!??!? HUH!!!!!!??!?!!
denbownium
Am I the only one that thinks it goofy that, in order to buy the front hinge pin holder (the little piece of black plastic that secures the front arm pins to the chassis), you must purchase the Servo Saver kit and not the Front/Rear suspension kit that has all the other hinge pin pieces for the rear?!!?!?
Its not here ....
https://www.horizonhobby.com/produc...mount-set-1-10-2wd-circuit-boost/ECX1092.html
It's in here .... (huh? why???)
https://www.horizonhobby.com/product/servo-saver-set-all-ecx-1-10-2wd/ECX1028.html
Not to mention, I wish Hot Racing would make an aluminum version of this. In the end, i will probably just make my own. Function over form.
A associated b4 front bulkhead is very similar to the amp part. And cheap, I got one for less than $3 at my lhs. It’s really close but I didn’t end up using it.
