Hi guys. Some assistance please.
REDdawn6
Hey guys. I have a second 1st Gen 2wd Ruckus. My step son gave it to me for his brother. It already has metal trans gear, 32p, Traxxas axles. I have a fast eddy bearing kit coming, where do all the different bearings go that come in the kit? Thanks, RED. I know about the trans gears and the axles.
That's all the spots for the bearings. Inside the transmission and then 2 per wheel is all there is. The rear wheel bearings go often, so its worth getting extras. The rpm rear hubs come with larger wheel bearings, resulting in longer bearing life, so its a good upgrade.
No, not on the stock set up.
One thing I like to do, is pop one of the bearing seals off, and add some marine grease. The ones on the wheels and the outputs of the transmission are the more important ones to do. What this does is helps protect those bearings from moisture and prevents them from rusting and failing prematurely. It does add more resistance, so if you are just racing in dry conditions, it's not necessary.
