More on my build and it’s getting good
Marc7215
so got my axle extensions and 2s battery in today and got them installed this thing is getting more capable everyday I’ve gotten rid of most of the torque twist by installing o rings over the shocks and I’ve moved everything towards the front...battery tray was flipped around to hold that new 2s over the front plus I moved the esc under the battery towards the front also. I installed the 20mm hub extenders and it made a heck of a difference having the wider stance I plan to keep the stock tires but I shaved some lugs off and it gives it the perfect bite and after taking it out today my aluminum bumpers are working perfect tomorrow some weights shock oil and lipo alarm will show up
654CBB3D-3414-4BF2-A5A1-F712CB8CC233.jpeg EB14C81F-70BC-47E3-818F-4B4AB9DE5B7A.jpeg 91B27A42-7DC2-448E-8668-61C44F443268.jpeg 3AD7768D-5BD8-41C2-857C-C24AE8C030EE.jpeg
I have rc4wd 1.7 siped super swampers on mine, they're great tires but they're pretty tall. I like them, ordered some 19mm wideners by junfac. How do you like them?
The wideners help a lot keeps it from rolling over as easy along with helps against the torque twist I need to probably get some taller tire but for now the stock tires are doing a great job I definitely recommend putting some weights on the rims also that made a huge difference also838BE052-BDD2-495E-8408-2235E91F505A.jpeg19201DFF-8E0E-4037-9607-1767B598F7EA.jpeg16E3FB6D-3F9B-4E06-9D90-9542EAB2D06A.jpeg
The wideners help a lot keeps it from rolling over as easy along with helps against the torque twist I need to probably get some taller tire but for now the stock tires are doing a great job I definitely recommend putting some weights on the rims also that made a huge difference alsoView attachment 3279View attachment 3280View attachment 3281
nice! I might weight my fronts when i get a better servo. Do you notice any more flex with the extra width? 20180330_113312.jpg 20180329_200509.jpg
Here's mine i recently completed. I put the stock shocks back on because ot made it to high for my liking. Nice build btw!
DCC0A894-33A3-4203-8DF3-77EC0D642914.jpeg 29D08E42-6C19-4E20-A9EE-CC740CC1E67D.jpeg
nice! I might weight my fronts when i get a better servo. Do you notice any more flex with the extra width? View attachment 3282 View attachment 3283
WOW!!! I like those tires a lot. And the body looks great....:the stock servo on these things are pretty good servo u could do the weight now and be fine I put 1 ounce in each front tire and 1/2 ounce in each rear tire helps the tires dig in and bite more...I actually lost some flex trying to fix the torque twist Because I filled the shocks with 30wt shock oil and compressed the springs with 4 o-rings each but u will get some more flex with the wideners
View attachment 3284 View attachment 3285
That's good to know, thanks! I might have to try that wt oil since i have some left. Not gonna mess with it for now. Thanks for the response.
