Need Replacement Front Spindle
ashtonp9
Hey guys, I have an Amp DB and over the weekend the bolt appear to be stripped out of my right front spindle. I am having trouble finding a replacement, any help is appreciated thanks!
I have these installed on some of my behicles:
https://www.ebay.nl/itm/RPM-73292-F...2WD-Torment-Ruckus-Circuit-Boost/382536755252
They are beefier, but you do need bigger bearings!!
If I'm correct, the standard bearing size is 5*10*4 mm, you will need 5*11*5 mm. Please, if someone here has done the same; can you confirm the bearing size?
Also, the stock front knuckles are way too bendy. On itself not a bad thing, because the flex keeps them from breaking. However: that amount of flex is usually the part causing the kingpin screws to fail.
The RPM spindles (with bigger bearings) used with these:
https://nl.aliexpress.com/item/4000333213732.html?spm=a2g0s.9042311.0.0.27424c4dL2oKmt
is a combo that has served me well.
Just check if the spindle isn't binding on the knuckle; if they do, just shave the connection points of the spindles very gently and test the fitting regularly when doing this mod.
Since I have used them on mu cars, I have yet to witness a spindle related faillure ;)
-Dave
EDIT: Just found some ECX 1065 off of ebay so were all good!
Thank you for the help guys! Got some stock replacements off ebay and now I need 2 of these screws, anyone know where to get these? Thanks!!
