Thanks for the reply. Which brand is best? I managed to get the connector back together but made a huge mess of the solder since I'm new to doing it. Since you mentioned they aren't meant to be reused I'm thinking probably spring for a new one instead.you would need to get a new end first, those ends aren't meant to be reused, I use deans silver solder on all my rc conections. If you are still useing the wall charger I would look into getting a better one, dynamite makes cheaper ones
Went to my local rc store near me in durham. Found a pretty good charger that will do 7 different types of batteries. Seems like a good fit for the price.
It depends on exactly what battery you plugged into it. If it was the 1,800 mAh NiMH stock battery then that looks correct.Is this screen accurate? I set the voltages as best I knew how from the booklet..then plugged the charger in then the battery and when I turned it on i got this.
