Servo Horn Replacement & Body Question
1st Drill out your wheel hub with a 7/32 bit.
2nd Insert the barrel nut into the wheel (the long silver hollow bolt)
3rd slide hub widener onto axle shaft
4th line up wheel an tighten barrel nut
I picked up a set of the Boom Racing wheel wideners. The exact ones that the link shows above. I cannot for the life of me figure out how to install them and they came with no instructions.
Can somebody help please??
@BliZZard911 They will replace your stock hexes. There should be a cross-pin under the hex - leave it there. Install the hub extender in place of the hex. You may need to drill a wider hole in the center of your rims (guaranteed if stock rims, I think a 7/32 bit or similar is about perfect). Put a lock washer, then the flat washer on the tube nut, and install your wheel using the tube nut to tighten down. Some folks have had issues with binding if tightened too much, so keep that in mind. I tightened mine down until the lock washer does it's job, no more.
After that, battery up, check your steering throw (and adjust if you lessened it for the bigger tires), and drive.
