Turns after throttle is first applied then goes straight
maphill
The Ruckus, when you apply the throttle, will turn to one side for about 1 second then drive straight again.
I don't believe this is due to torque steer. It happens with gentle throttle and when lifted off the ground. It's like it is getting a momentary signal to turn after starting the throttle. Once moving (if you don't lift the throttle), it drives normally.
Issue in the transmitter? In the ESC? Or something else?
Thanks,
Mark
