RandScustoms
I have a 2wd torment and I've replaced all the gears and the axles and I'm not sure what the problem is I've tried a lot of things and the rear wheels keep locking up.
Note: This feature may not be available in some browsers.
I replaced everythingDid you open the transmission? You said you changed the gears, did you mean just the pinion and spur? Probably something stripped inside of the transmission.
Thank you I well check when I get homeLoosen up your motor screws and pull the motor away from the spur gear so that the pinion and spur aren't meshed. The spur gear should turn freely and you will see the drive shafts turning. If not, take the transmission cover off and see if your idler gear or one of the other gears is bound up.
There are four screws that you screw into the bottom rear of the truck. The screws hold the transmission in place. If the screws that you use are too long, they will go up into the transmission and stop gears from turning. I know this from experience.
It dosent spin very smooth it feels like it's going out it's not grippingI swore I wrote a response last week. Maybe I never hit post reply. I wrote right after max-d, to check how the motor spins when it's disconnected from the spur gear. Motor could be on it's way out.
