Try the barrage Doomsday drive shafts I too am running 3s lipo and also doomsday 390 motor and having no trouble with the drive shaft so far which are a lot bigger than the stock Gen 2 drive shaftshas anyone found metal driveshafts to fit the temper gen 2. running 3s lipo and shredded both of them
No problems installing the other motor same diameter just longerThanks. Did you have any problems fitting the larger motor?
[QUOTE="Iriejohn, post: 19047, member: 2247"]
[/QUOTE]
Hi,
Just seen your old post. Did you manage to find and fit an uprated set of driveshafts. Mine are broken and stock ones are 2mths away.
Many thanks.
Brendon
