Post a picture of your setup. Best way for others to help you.
I updated the original post, you can see the metal pin in the shock came out.
I was under the impression I rebuilt it correctly but maybe I’m doing something wrong for it to keep popping out.
That’s why I was looking for a build video for it.
Here is an exploded view of the rear shock.
I don't see anything special besides the e-clips and piston. Perhaps your shock shaft has the grooves that the e-clips sit in worn? Or maybe the e-clips are loose/ worn?
I would likely try replacing the e-clips.
Thank you, I’m going to break mine down and post a picture.
Those e-clips are so small, is there a maintenance kit I can order that has extras of these small types of parts?
Also, where did you find this expanded picture?
I'm not an expert mind you.
When you say, you pulled hard and the shaft comes out. I assume it's only the shaft? If so then I would say the E clips are sprung open and not holding firm to the shaft. Are the E clips easy to snap onto the shaft? Other than being tiny and hard to hold onto.....LOL
