K&S metals at a local hardware store...WAS THAT WIRE FROM SOMETHING? OR HOW DO YOU FIND A WIRE LIKE THAT?
I don't get it. So you drilled out for rod to be inserted?
I'm just curious how your twisting shafts?
How much power are you putting to the wheels?
I have done some serious climbs and still have not broke. I am even twice the weight from stock and more power to wheels.
I am just really curious. Maybe I am just lucky.
There is already a hole in the drive shaft....I don't get it. So you drilled out for rod to be inserted?
I runI actually run the barrage driveshaft in the front and that hot racing in the rear on my gen2View attachment 5489
I run them front and rear. I just got out the grinder and filed down the driveshaft end till it fit past the transmission case. Works great.I run a barrage transmission in my Gen 1 with the larger barrage drive shafts, they’re much stronger. My buddy that has the Gen 2 wishes he could run them but they won’t fit a temper transmission without grinding away some of the transmission case to clear the shaft.
