When you say smaller, is that more teeth or less teeth?The stock plastic is an 87t so if you're changing to a 87t metal, the stock pinion should be fine. A smaller pinion and/or larger spur gear will give you more torque/acceleration. A larger pinion and/or smaller spur gear will give you more top speed.
Thank you for your replySmaller would be less teeth
